Actualizacion HomeY Pro 13.2.0 estable
1 Replies, 235 Views
Hoy nos llega una actualización del hub a la versión 13.2.0
[Imagen: Untitled-2.png]
Después de 5 versiones betas, por fin hoy llega la versión estable de esta 13.2.0
v13.2.0
Core
Updated translations.
Z-Wave
Official Z-Wave certified implementation.
Updated Z-Wave chip firmware to version 7.21.6.
Added SmartStart support. Devices can be added by scanning a QR code or by entering the DSK.
Added support for controlling door locks and thermostat mode/setpoint from the default Z-Wave device.
Added S2 multicast security support.
S2 now grants all requested security keys (except S0) instead of only the highest.
S0 can be enabled from the advanced settings when pairing a default Z-Wave device. Disabled by default.
If security bootstrapping fails during pairing, the user is informed and the node will be removed.
Improved handling of multiple decryption attempts for multiple security keys.
Incoming messages with too low or no security level are now ignored.
Associations are now validated against the destination node's supported security and command classes.
Return routes are correctly assigned when adding associations.
When a node is removed from the network, corresponding associations on other nodes are also removed.
Association group names are now retrieved from the node and shown in the device settings screen when not defined by the app.
Battery devices are now correctly and faster put back to sleep when there is no more data for them.
When changing settings of a battery device, an estimation is given for when the device will wake up. The result is shown in the timeline.
When changing settings or associations on battery devices, the result is shown in the timeline after the device wakes up.
If a device sends a Device Reset Locally notification, it is removed from Homey after verification.
Added Inclusion Controller support.
Improved Security S0 handling.
Improved Transport Service handling.
Developer Tools
Healing a Z-Wave node now also updates return routes for all association destinations.
Added 'Update Z-Wave Routes' feature that performs a neighbor discovery of all non-battery Z-Wave nodes and assigns new return routes when needed.
Added 'Identify Z-Wave Node' feature. The node will flash a light or make a sound.
Testing a Z-Wave node now sends a NOP command instead of BASIC GET.
The list of pending Z-Wave SmartStart inclusions is now shown and new entries can be added.
When the Z-Wave network is reset, a Device Reset Locally notification is sent to nodes in the Lifeline group.
Zigbee
Adds endpoint for viewing source route table.
ha generado muchísimos fallo esta actualización, destrozando por completo la red zigbee a muchos usuarios...
Os dejo aquí como lo ha conseguido solucionar..
(Última modificación: 22-05-2026, 12:33 PM por Toni.)
